ATI Radeon X1300 Pro 256MB DDR2
1 Dec 2004
S.Wales
What do people think of this card? i need a replacement as my 9800pro died, i dont really game, i think iv played 2 games in the 2 years so i want something that will run the odd game.
I will be using it on a PC running a widescreen monitor at 1440 x 900 screen res
I would like to stick with ATI cards as i have had a better experience all round with these over NVidia.
I need an AGP card with a £50-£60 budget that will allow me to play the odd game
You can get new AGP 6600 GTs (an upgrade, pretty small one but still an upgrade) for under £50, AGP 7600 GS (quite a bit bigger upgrade) for a little over £70. The X1300 Pro is a downgrade to what you have and the X1600 Pro sucks too (though it is quite a bit better than an X1300 Pro and wouldn't be much of a downgrade).
The low end ATI cards aren't very good I'm afraid, the X1650 Pro sucks on AGP too (though it isn't that bad on PCI-E), the decently competitive ones start around £90 (on PCI-E), as the X1650 XT is comparable performance to the 7600 GT and the X1950 Pro (on AGP and PCI-E) is pretty competitive and decent value.
Your best bet imo is to buy a second hand X800 / 6800 series card.
I am using one atm.
Pros:
Works well in Windows including Vista
Can be Crossfired without need for master card, just get two X1300's
Mine is passive cooled
Plays UT2003 / 04 at 1920x1200 without stuttering
Cons:
Gets quite hot
No good for complex games like F.E.A.R. or Oblivion
Hope my comments help.
EDIT - Mine is not PRO, only the basic.
I have one;
adv:
dual link dvi
small, doesn't require power connector
can do 1280x1024 with details on med-low on recent games with good fps
dis:
the asus model has a stupid custom fan and layout
no auto thermal fan speed control
considering how small it is, it seems to generate quite a bit of heat from the small active heatsink.
