ATI Tool still not working!
Suspended
17 Mar 2006
I've installed the latest Omega drivers, installed ATI tool. But ATI Tool just doesn't seem to find the X1900XT?? I have 25 beta 14. Do I neet .net? What service does ATI Tool require?
I've just uninstall Omega, install net, installed full ATI 6.3, and still ATI Tool doesn't show X1900XT! :confused:
i couldnt even get it to run on mine, came up with cannot read information form the bios. i gave up and went back to ATI drivers.
ATi Tool does work, it doesnt detect 3D speeds, create a profile, set fan speeds you want (or it will overheat), set voltages, set clocks.
Remember to save to the profile each time.
Also the ATi driver services have to be disbaled in services.msc. Also ATi Tool + CCC DOES NOT WORK PROPERLY. You have to use the old control center or ATi Tray Tools by disbaling the overclocking section when installing.
Stock Volts in 1.4V for XT and 1.425V for XT-X, mem voltage is correct at 2.089V.
Conc
