ati tray tools fan speed
23 Aug 2004
OK,
I've set my fan speeds to change depending on the temp of my X800XT. Problem is, when ati tray tools runs on start up it sets the fan speeds to the automatic values and i need to load my profile to set it to the speeds i want. Anyway of making it load my profile speeds as default?
Yes open ati tool, goto settings (bottom right corner) then from the drop down menus at the top choose startup you can then choose what profile you want to load up when you boot up the pc.
