ATI tray tools / overclocking disabled.
27 Apr 2004
Doncaster, S.Yorks
As title really, i have a X1800XT 512mb and in ati tray tools it says overclocking disabled and i cant monitor the temp in system tray anymore as they are greyed out...anyone else have any problems
drivers im using are the omega ones (latest) so ATI Tray tools is with it.
This is what should be in your atitray.ini
Code:
[main]
; update information
; do not change
update_server=www.radeon2.ru
fileurl=/atitray/update.ini
; disable overclocking at all
; will be useful on unsupported hardware
opt_disable_ovr=0
; interface settings
; d3d/ogl can be hidden only when ATT is not in Control Center mode!
hide_ogl=0
hide_d3d=0
hide_tweaks=0
hide_timings=0
; Context Help File
help_file=atitray.hlp
; disable checking for supported device in TV/Display module
opt_disable_dcheck=0
; use old I2C access method
; for R5xx I recommend to set 0
opt_old_i2c=0
;do not wait for Access_ATI_I2C. Common mutex for all software which access  I2C on ATI Video Boards.
opt_nowait_i2c_mutex=1
; disable I2C control functions
opt_disable_i2c=0
; Use old BIOS detection procedure
opt_oldbios_detection=0
; Swap Temperature 0 and 1
opt_swap_temp=0
I had to renistall my ATi tools to get the overclocking option enabled.
there's an option during install which you have to selet (or deselect, I can't remembr) to allow OC'ing.
I couldn't find any other way.
