ATI Tray Tools
18 Jul 2004
ive just installed ati tray tools, is there a way i can get it to display the gpu temp without having to open it? like a number in the taskbar or int he buble when you hover over the icon in the taskbar
Yeah, there is a way to enable the temps in your taskbar.right click on the ati tray tools icon, go to Hardware, then System Tray Hardware Monitoring, and enable what you want there.Hope that helps
