ATI VIVO HELP
19 May 2003
Under a rock
Right, last night id thought i would take advantage of the VIVO on my x800 and run my GameCube through it :D
Anyway had a quick dable and found that i needed to install the silly ati multimedia center :/ so i went ahead and got it install to find out that the TV part of it wouldnt load, it said it couldnt load the driver or summat. So i uninstalled the CAT 5.7's that i use (find them best for CS:S!) and installed the new 5.13 cat's with the crappy bloated control panel.
And it still didnt work, but when i loaded up Microsoft Encoder which came with the Ati Multimedia Center that could stream the video feed from the GC!
Anyone got any ideas on what i need to do to get this working?
The exact error i get is ""capture driver is not loaded nor enumerated by the de..." then under that it says "ATI Rage Theater Video Capture"."
