Morniing,
It's been a long while since i've had to troubleshoot a gfx card issue.
I've just built a new rig with an X1900 256Mb powercolour PCI-E card.
Firstly, i'm using Vista 32 bit and the latest Ati drivers. The original drivers were uninstalled first.
I loaded up Stalker and it crashed within minutes, there are also stretching elements and other corruptions.
I loaded up 3dMark06 and it crashes after 2-3 minutes.
I used SiSoft sandra in burn in mode and the rig stays stable for over an hour.
So i'm guessing it's something to do with the card. So I load up ATI tray tools and switch on monitoring. Here are the first and last results before the machine locks up during 3DMark06
Any guidance would be appreciated.
Memory Clocks (MHz) - 594.00
GPU Temperature - 58.00
Environment Temp. - 52.00
Fan Duty Cycle - 27.27
Main CPU Usage - 12.50
FAN Rpm - 1969.00
Temp 1 - 40.00
Temp 2 - 51.50
Temp 3 - 119.00
Memory Clocks (MHz) - 720.00
GPU Temperature - 89.25
Environment Temp. - 61.00
Fan Duty Cycle - 50.00
Main CPU Usage - 64.06
FAN Rpm - 3327.00
Temp 1 - 41.00
Temp 2 - 65.50
Temp 3 - 124.50
FAN Rpm - 1969.00
Temp 1 - 40.00
Temp 2 - 51.50
Temp 3 - 119.00
FAN Rpm - 3327.00
Temp 1 - 41.00
Temp 2 - 65.50
Temp 3 - 124.50
If its not running stable, may be worth considering an RMA. If it turns out not to be the fan, then it may be a voided warranty for nothing
