ATI X1950 pro
24 Jun 2004
wrexham
Hi
I brought this card from overclockers it came today, but in ati tool ver 0.27
the mem is only at 648.00 is that right as on the web page it says 1.30ghz. The core is right or is it the ati tool i have tried other versions but this is the only one to read the clocks at all and does anyone know how you can read the temp? nothing in ati tool gives a clue.:confused:
cheers nick
Hi
cheers nick
it's ddr memory so you have to double it ie 648 x 2 = 1296 memory speed so close enough.
Everest works really well for temps including cpu, chipset, gpu, seperate core temps and all your fans on one screen.
Agrees about everest, ATiTool can also be used to control the fan speed if you dont fancy everest for that.
Can't fault the card, had it for a good few months now and has been working flawlessly, just about to have another go at Farcry as not played with my new setup yet.
Also another quick note, with the new catalyst drivers it is now possible to overclock the GPU on the 1950pro. Had mine working at 612 Core with no probs but the memory cant be touched as it crashes straight away.
