atk0110 ACPI Utility
30 Nov 2007
im just about to do my dirst winows update since fresh install and ive come across this in the update list "ATK SYSTEM atk0110 ACPI Utility "
Does anyone know exactly what it is and do i need it ? ive read a few googles and its hit n miss with various people, some say its installed with no issues, other say they installed and have had endless issues
what should i do ?
but what exactly does it do ?
and what happens if i decide not too
just abit dubious as ive never seen it before thats all
thanks for reply too
what it did for me was randomly blue screen my windows 7 machine. until i replaced psu, cpu and ram. then realised the only common thing between them was windows updated always installing this ARRRRRGGGGHHHHHHHH
but i got a nice little upgrade out of it
Well it can't have been a driver update issue if the problem was solved when you changed hardware....which means the driver update used a part of your hardware that was faulty hence why you only got the BSOD when it was being utilised.
ATK*** is always installed here, it's required for proper power management etc.
apologies, the hardware changed made no difference at all.
only when i stopped this installing did the blue screens stop
