ATMOS High Speaker Upgrade, worth it?
5 Mar 2007
Macclesfield
Hello All,
I'm thinking of upgrading my ATMOS High speakers (full specification below), I read good things about the:
Dali Alteco C-1 Speakers
Do you think it's a decent upgrade and or worth doing given the rest of my set up?
AMP - Denon 2700h
Front L/R speakers - q3059i
Rear L/R speakers - q3020i
Centre - q3090ci
Sub - BK XLS200-FF
ATMOS Highs - Cambridge Audio Minx MIN22
(all white)
Any advice appreciated.
Cheers
Thanks @hornetstinger, not sure why I didn't think of that as I actually have a couple of 3010i's connected to my second PC...will swap them with the MIN22's and see how it sounds...
Any suggestions on how to ceiling mount them? (think that's why I didn't consider them)
concept 500 look a little out of my budget!
Assume the 3010i's will fit in the 3000WB Bracket...picked two up from ebay so will hopefully be able to use those...
Cheers
Cheers @hornetstinger
Do you know the settings I should use on my Denon with the Q Acoustic? I specifically find the crossover and LFE confusing!
As ever advice appreciated!
Cheers,
Cheers,
Typically 80hz for all the speakers.
120hz lpf in the denon for sub
Disable the subs own crossover or set it to maximize on the sub plate back panel
Maybe center to 90hz
Could try 3050i as 60-70hz
