Suspended
- 23 Nov 2014
- The Cronx
So forum…
I have an LG B7 with hdmi arc 2.0. I only use the tv apps or sky stream box. I have a Sonos arc plus sub plus 2 era 300s.
Sounds great, however as I understand it, quality (wow factor?) would be better if I had arc 2.1.
I think the options are
1) only use the apps on the sky box, get an audio splitter for hdmi to the sonos (done this in our kitchen, sounds ok)
2) get some chunky av receiver to do the same as the above….but would this be any better?
3) new tv
Normally I’d just do 3, but I’ve literally run out of tv donation recipients. Is option 1 just snake oil? I did it in our kitchen because I mounted a 17” portable monitor on a flip stand and obv. it doesn't have any other sound options and it sounds fine (sonos beam and 2 x sonos 1s). But I want (or need to know I’m getting more likely
) the best possible output on the main setup. This what I have used in the kitchen: CMSTEDCD HDMI Audio Extractor 4K x 2K@30Hz HDMI to Optical Audio Adapter HDMI to Spdif Toslink and 3.5mm L/R Stereo Audio Converter Support DTS-HD/3D /Blue-Ray/Dolby-AC3/PS3/PS4/HDTV https://amzn.eu/d/hyvBpwL
Any help appreciated, even if just to confirm my conjecture that I should just buy a new TV and stick the old oled in the garage (there is no donor room, they all have tvs already).
Edit: had the B7 since 2017 iirc
3) new tv
