Attaching a fan to this CPU cooler?
Here is an overhead pic of mine - any help?
Basically the clips hook round an indented part of the cooler and hold on to the corners of the fan (look at bottom fan). Its actually very easy to do and the instructions should clearly describe it (i have since binned mine).
No problem :)
The megahalems comes with one set of fan clips (so you can attach one 120mm fan). I believe OCUK are about to start listing extra fan clips for the cooler - so you can attach a second fan.
Personally, I used a TRUE fan clip on my second fan. Its not perfect though, and plan to replace it with a proper megahalems one later this week.
Pretty much. The direction of airflow is the same as you put there but they spin in the opposite direction (no affect on the principle though).
As the Antec has a nice big top exhaust fan, an arrangement like mine would make a lot of sense.
