Attaching lens caps
12 Sep 2005
Grundisburgh
Unfortunately my 2 lenses have different sized caps.
How can I attach the cap string to the lens rather than the usual camera point?
Andi.
On this note (not worth a thread of it's own), does anyone know of anywhere cheap to get Fuji X(T10) rear lens caps? A quick look on Amazon, £5 seems a bit steep :o
Sure, but I only need them because I bought a Nikon F to FX adapter, therefore will be using/carrying my Nikon 50mm and Sigma 70-300mm. One of those needs an FX cap unless I want to keep taking the adapter on and off.
