Attaching Polythene Sheet to Bare Brick?
17 Nov 2003
Midlands
Does anybody have any suggestions on what could be used to attach polythene sheeting (think dust sheet) to rough bare brick? The sheeting is being used to mask a large area.
So far standard duct tape and Gorilla tape have been unsuccessful.
Any recommendations, ideas or thoughts?
If duct type won't stick then you're probably a bit stuck(or not) unless there's a specialist tape for this sort of thing which wouldn't surprised me but then I bet it's not cheap.
I'd have thought stick a patch of duct tape on in various places and nail through those places would hold it well enough against all but the most extreme weather. (EDIT: Getting a seal around the edges could be a bit harder - depending on size maybe a wooden frame?).
Wooden frame! That's a good idea.
Doesn't have to be a perfect seal i.e. liquid sealed, just enough to stop a majority of dust and debris.
Thanks for the suggestions so far!
