- 25 Jun 2009
- Middlesbrough
I'm currently using Rothwell inline attenuators between my CD and amp (Musical Fidelity A5.5 and KW550). Cables are Kimber Select KS-1011. I've been told (and read) that the inline type are not too good and I should get my cable changed/adapted to built in attenuation.
Are inline worse than built in, or would I not notice a difference?
I do have an old pair of interconnects that have built in attenuators, so I could (carefully) remove the resistors from those and solder on to my main cables.
Is this worth doing?
(The Rothwell inline attenuators are -10dB and the fitted ones are -16dB).
Any advice would be gratefully received.
