ATV2 with XBMC Opinions
15 Dec 2002
In a cowfield, London, UK
Hi folks,
Recently I have purchased a Boxee box in order to play 720p media on my network. This unit was to replace my JB'd ATV1 running XBMC. The ATV1's aging Pentium M was just not upto the task of playing high res content so I sadly had to look elsewhere.
Boxee seemed the perfect choice, as I didn't want to dabble with building a HTPC. I received my Boxee last week, and despite it being able to play hi-res content off my network easily enough - I am not happy with the purchase compared to how smooth and easy XBMC was to work with.
The fixed media scraper on Boxee is just horrible and can't recognise half my tv shows like Knight Rider (1985) or Thundercats (old). Movies are fine. By comparison XBMC has this mastered to a tee. I spent two days renaming a ton of TV shows and half of them still aren't picked up. Then there's the boxee remote, which is RF based instead of IR, meaning I can't program my Logitech Harmony One remote to replicate it's functions.
I am considering returning this unit, and looking at XBMC on a JB'd ATV2. My main question to most of you ATV2 users is - how well does it run XBMC, and how well does that handle 720p/1080p content off network shares?
Boxee is a great bit of kit tbh, very silent and has yet to even get warm to the touch. However the software just lets it down. There is a beta build available, which I shall try tonight though. Overall the software, despite being a fork off XBMC has a long way to go.
Cheers all!
I'm running an ATV2 as well. No problems with it all, once I'd stopped trying to use a flaky wifi connection and switched to powerline connectors. I've only tried it with 720p content though... I believe it downscales 1080p anyway.
It may get decommissioned if the Raspberry Pi turns out to be an amazing XBMC platform but we'll wait and see. Until then, it's by far the best solution.
Paul.
Thanks for the feedback gents. I had the feeling the ATV2 would be the perfect platform but I chickened out thinking it would run too hot - like the ATV1. I keep forgetting the unit lacks the main source of the heat - the hard drive.
I'll check out the new boxee update tonight and do some research. Ta!
Sod it, sending back the Boxee and just ordered an ATV2. If Apple release a successor this January, all hell will break loose.
Indeed. Can't see an ATV3 coming anyway and the 2 has more than enough power for my needs from the looks of it. I'm just reading the ATV2 teardown at iFixit. The unit is so compact!
Sure is! A friend introduced me too it a few weeks ago and its great.
However, Megaupload can be abit flakey even though my connection is 50meg! Have you figured out how to make it auto start the next part when watching a film? Really need to figure it out!
(Sorry for OT).
I've only just started with icefilms, really surprised working great so far even on my 2mb BB!
Yeah a couple of things I need to work out if you can pause and pick up the tv show/film later. FFoward and Rewind.
Seem to be missing quite a lot of fanart too :confused:
Cheers for the heads up guys.
Got the ATV2 today and was up and running in minutes. I used Seas0npass to do the JB and had XBMC (Eden) on the little device in no time. I find Eden somewhat sluggish to use atm (even on my main pc), it could be the software or just the Confluence default skin I guess. I've turned off fanart to speed things up. I just need to look into all the other software on offer now!
HD playback seems nice and smooth so I am happy there. It is incredible how tiny the device is when put on top of the ATV1...
http://twitpic.com/86fbam/full
Are any of you guys running the 4od app? I've got mine working, it sees all the content but when I started watching the 10 oclock show last night it kept crashing, then I went for the download option and it started going on about rtmpdump at which point I was lost!
