ATX 2.0 = 2.2?
10 May 2004
Sunny Stafford
One of my computers is a tower case with a stock ATX 2.0 PSU. I would like to get this which is ATX 2.2. Will the screws still be in the same position. I just want to ensure that 2.0 and 2.2 have the same fittings. Thanks :-)
Yeah the screws will be in the same place, can't remember what the difference is, think you get an extra couple of motherboard power connectors.
Jokester
In case you care (and there is no reason to since Jokester pretty much summed it up) there is a 432k PDF here listing the requirements for the ATX 2.2 specification, the changes are minor hence the 2.X designation rather than the X.0 designation but essentially in physical changes it amounts to a change from 20pin to 24pin plug for the motherboard to get the ATX 2.2 compliance.
