Hello all!
Nearing the end of my first build, and I've noticed that the 8-pin ATX socket at the top of the board has a blank in it, covering the four left holes. The PSU has a 4-pin cable that fits the 4-pin hole, as well as plenty of 8-pin connectors. The manual doesn't mention anything to do with this blank, and simply tells me that forgetting to plug this 8-pin connector in will cause the system to not boot. Having had a little search, I found this thread, (http://forums.overclockers.co.uk/showthread.php?t=17743980&highlight=atx+power+blank) which would suggest that it is simply there to "reassure" those who only have 4-pin connectors, and should be removed. Could someone confirm this for me? Probably a fairly well known fact, but like everyone first time around, I'd rather not mess up!
Cheers!
Cheers!
