Hi all,
Whilst building my rig I've run into a problem with the ATX 24 pin power cable and it's slot on the mobo. The Mobo is a Gigabyte Z77X-D3H and my PSU is a Seasonic X-Series 760w fully modular PSU. Basically, the cable just won't go into the slot on the board, even when using a level of force I'm uncomfortable with. I had to RMA my previous board because one of the ATX pins was bent, which I fear may have damaged the ATX power cable. What should I do? Try again using more force? Try to return the PSU cable? I don't have a spare PSU or mobo to test either one against either...
Many thanks,
Ozzy
Many thanks,
Ozzy
