It'll live in the living room on computer desk's top shelf. Shelf edge is 45cm from the back wall, so the front feet have got to be no further than that, also, will need no less than 8cm clearance from the wall for the cables. Shelf width up to 50cm, and height N/A. Currently using a Silverstone LC03 in the same spot, but want an upgrade to a newer case, and in black. It'll be in the living room, so noise is important, and I'll be looking to house an AM3 gaming system in it, so cooling is important. Doesn't have to be a HTPC case, just as long as it fits the criteria.
HELP
EDIT
The shelf is 35cm in depth!
HELP
EDIT
