Audacity - Record what you hear
3 Nov 2005
Stoke-on-Trent
How do you use the option to record what you hear in Audacity? .
Should it be here in the box that is greyed out?
Cheers
Check the preferences, you may need to set your recording device and restart the program. I'm not sure if you have the "What U Hear" option on none Creative cards or an alternative.
I have tried sorting this out on my machine, but there IS a way.
Go into the recording volume control and UNMUTE 'Stereo Mix'. Again, inside Recording Control lower the 'Recording' input to say the first bar.
Go into playback, lower the channel labelled 'Wave' a couple of notches down.
Play some music and go to record in Audacity to check if it sounds OK as you may need to lower the Wave or Main 'Recording' to reduce distortion.
Hope this helps.
