Audeze mobius no sound in doom?
24 Feb 2004
The tittle says it all unfortunately, don't get no sound with Doom 2016, everything else is fine. I can't seem to find out why.
bought a pair recently and not entirely impressed with the sound but given they are wireless they are good, wel best of all the wireless I have hear apart from amirons but those are not fit gaming.
the only issue I have with them is the sound I'd nasally and tad bit too much treble but bass is good sub bass extension is not as good as other cans but midrange is perfect on these. They have good soundstage but not AKG level by long shot, only issue is they sound nasally sometimes.
You can adjust the soundstage in the software and select various EQ's to suit your taste all engineered by Audeze.
Have you entered your head measurements into the HRTF section of the software?
Which sound settings do you have it set on in DOOM and have you set 7.1 and is 3D sound on? Only time I'd say they are nasally is if you have them set on stereo with 3D off. Soundstage you can alter to be massive with 3D on.
Not sure why wouldn't work in one game but work in everything else. Did you check the volume mixer when Doom is playing to see if it's outputting to the right device?
Also you need to follow the advice that WoodSta gave you. Setting the proper head measurements is important to getting the best sound quality.
Another thing you should do is download the latest AudezeHQ app and update to the latest firmware. Makes a difference to the sound quality. I think you will like the changes.
