Audeze Möbius usb type c cable.
12 Mar 2013
nottinghamshire
Hi guys. Have any of you Monique owners had to replace the usb type c cable yet. Mine seems to be faulty and I've looked and official cable kits are £25.... Was wondering if a standard c type usb cable would work ...cheers
As above any cable will work.
If a different cable doesnt change anything it's more than likely the headset.
I had problems with actual socket after a year of use and I've read many reports of the same.
Cheers guys...I've ordered a basic cable now...hope it's not the connection in the headset.....btw did you get yours fixed or ditch the headset?....
Any cable will work. Don't think it will affect sound quality as the signal is sent digitally to it.
