My Audigy 2 ZS supports 7.1MeatLoaf said:The main difference between the audigy 2 and 4 is the audigy 2 only sopports 6.1 sound whereas the audigy 4 supports 7.1.
They all use the same drivers according to the creative website as the latest driver set is labelled for augidy 1 thru to audigy 4.
smids said:My Audigy 2 ZS supports 7.1
I went for the A2ZS because I don't think the A4 has a joystick port (midi) but I knew the ZS did. Someone please correct me if I'm wrong.
Ah, gotcha!MeatLoaf said:Sorry mate, i was referring to the original audigy 2. Smids is correct the ZS does support 7.1![]()
The X-Fi has more features and doesn't resample when playing music (under certain mode). I don't see much benefit from going ZS Platinum IMO. Different story if you were thinking A4 Pro where there is a difference (SQ vs Feature).mark1 said:To save me starting a new thread, does anyone know what the difference is between the Audigy 2ZS Platinum and the X-Fi Xtreme Music, other than the breakout box? They're fairly similar in price so which one will offer better overall performance?
Thanks, i have 5.1 headphones if that makes a difference as i've heard that the X-Fi is good at producing surround sound.
