Audigy 2 ZS Platinum OEM VS Blaster X-Fi
31 Aug 2006
Hello people
At the moment i have Audigy 2 ZS Platinum OEM and i have just got a pair of Harman Kardon Soundsticks II 2.1 Speakers , is is worth upgrading to Blaster X-Fi , or keeping what i have ? advice please
I listen to a lot of music only , don`t play many dvds or games , only games i play is COD ect
Yup, go for the X-Fi OEM, and you can also use the front bay from your audigy from it. ( You wont be able to use the firewore port tho unless you connect it to a mobo header )
ZUTON said:
I have seen Blaster X-Fi OEM for £126 including delivery , is that a good price :)
Which model?
The normal one from ocuk is £58. A retail one with the front panel is also less than £100
Also, watch out getting OEM X-Fi off the bay, as a lot of them are dell models and are not full X-Fi cards with some decoders missing.
Hmm, not bad, but id remove that link asap as its a competitor ;)
personally id spend the extra £15 and get ne from ocuk, or the extra £25 and get some free decent headphones :)
Or if you want the front panel, get the £58 one and hook your existing panel up to it
Sounds daft (pardon ze pun) but how much power consumption does the X-Fi OEM use? (As my PSU aint the biggest)
Been thinking of getting a dedicated soundcard, just not sure which one and how much.
£60 is a lot, but my last SB cost more than that and lasted my 3 full computer upgrades.
If its the psu in your sig it will be fine mate :)
Yeah it is, not sure how close am running to the wire with it.
PS: Whats the difference between OEM & retail, what do i get for the extra £20?
Cheers.
I think so. Is there a mistake on that page though? Both versions (with and without headset) cost £78.67, or do you have to add the headset to that? Otherwise the choice is obvious.
No, HP's are chucked in.
Maybe OC realised no one was buying the retail (and for good reason, £20 for a box) so they through in some headphones which probably cost them £10, but retail at £30, making the pack look buy-worthy again.
SC-034-CL is there for those who are too thick for free headphones ;) (its why i checked!) hehe.,
