Audigy 2 ZS problems
20 Jan 2004
** FIXED
after trying about 20 Creative drivers finally got the external box working.
Damn I am not buying Creative again.
What was the "fix" you used, as I have a friend who is having problems getting the breakout box (external box I presume) working....also if using XP, what drivers work for you?
Thanks. :)
Well also on the breakout box a pin was ever so slightly bent and that was causing it not to be detected at first.
I don't remember which one I used in the end, but I beileve I got it from Download.com or filefront. Just kept trying all the Audigy 2 ZS drivers until I got one that supported the box.
Think it may have been - Google - AUDIGY 2 ZS DRIVER - 3rd result down - from download.com. Try it.
