Audigy 2 ZS soundcard making clicking noises
24 May 2003
UK
I have had this card for around a year now and it offers excellent sound, so much better than onboard sound.
However there has always been trouble when I am listening to online video streams or playing online games, namely that the sound card makes irregular clicking noises.
I have just found out that the reason could be something called PCI Latency.
I have downloaded a patch from http://www.georgebreese.com/net/software/ and it appears to have fixed the problem despite the patch being BETA software.
In any case if I did suffer problems then I could uninstall it in Add/remove programs.
As to the cause, apparently it is a feature of the VIA chipset that my motherboard uses.
Finally according to a reference on the website:
"Warning! This does not install on Windows XP Service Pack 2 (SP2), or on Windows 2003, due to increased security on those versions."
Strange as it appears to have installed when I ran it as it is listed in Add/remove programs :confused:
TaKeN said:
Are you using Medusa 5.1's By Any Chance ?
No I'm only running 4.1 sound at the moment using a quadrophonic speaker setup.
Are you implying that those speakers can produce the clicking noises as if true I find that strange :confused:
p.s. my problem has now gone away since installing the patch!
I dont know if its of any relevence but back on my old Abit via kt133 baord, the magic bios option for enableing/disabling clicking on my audigy2 was an option called pci master read cache. Once that was dissabled , no more clicking/poping from the audigy.
I've never heard of a magic BIOS option and in any case I have a Gigabyte motherboard not a Abit one but I will check out the advanced features next time when I reboot.
I think that these only offer performance features to do with memory timings and such like and nothing to do with sound cards :confused:
the above option isnt specific to sound cards, just an advance chipset option for the kt133. the above was the option that sorted out the clicking. In regard to the pci latency patch, i belive at the time they were added to the via chipset pack of the time so was no need for a seperate patch. Id be quite suprised if via hadnt got there act together since then and have the issue fully sorted in newer chipsets.
MadMatty said:
i believe at the time they were added to the via chipset pack of the time so was no need for a seperate patch. Id be quite suprised if via hadnt got there act together since then and have the issue fully sorted in newer chipsets.
To be honest I wouldn't know what version of the VIA chipset I'm running!
The only VIA patch I've ever downloaded and installed is the VIA Hyperion 4 in 1 which was to do with my graphics card.
I am running the VIA KT 400 chipset which I know is way out of date but it serves me well and will continue to do so until I can afford to upgrade to a 64 bit PC.
I had this problem back when I was running an Abit KR7A-Raid mobo which used the Via KT266A chipset around 2001 :eek: was using the Soundblaster Live at the time, I used the patch & it seemed to do the trick well it reduced the crackling noise. . .
Well it has certainly done the trick here but to be honest I was a bit wary about installing it as it is BETA software but I'm glad I took the risk now!
By the way for some strange reason in normal use my sound was fine as it was only when I attempted to play online sound samples like from an audio or video stream that I noticed any crackling.
Also online games were affected, but in all these cases it was sporadic as one day it could be quite bad and at other times barely noticeable!
