Audigy 4 or X-Fi
18 Oct 2002
Brighton
I've decided to upgrade from my onboard sound to a decent card.
The PC is used exclusively for gaming and is connected to a Denon 5.1 amp.
My choices are:
Audigy 4 - £25
Audigy 4 Pro - (Can't find these anywhere!)
X-Fi Xtreme Music OEM - £58
Any thoughts?
Cheers.
I have the Audigy 4 Pro, its a good sound card with lots of freatures. But I would rather have the X-Fi by a longshot. If you can afford the Audigy 4 Pro the you can afford the X-Fi Fatal1ty FPS Edition with X-RAM ;)
Thanks, I was hoping to spend £60 max, picking up a second-hand Audigy 4 Pro if necessary.
I think the X-Fi seems like the best option. It seems crazy that Creative don't put S/PDIF on the back of their cards but I guess that's a ploy to get you to spend more money on the front panel.
