audio bus
13 Mar 2011
Ok guys a problem
I need to install audio device drivers.
Drivers wont install because the audio device is stopped. (cannot start)
How do I start the High definition audio bus?
gigabyte mobo GA-H55M-UD2H
WINDOWS 7 OS.
Thank you
I'm assuming that your talking about the on board audio??
First thing I'd do is go and check that it's enabled in the BIOS.
Hi olly, I 'm no expert around there.
I've checked and the azelia codec is on auto ? think that's what I'm supposed to be looking at ?
I've read further on intels site, I think what I may need is to re-install the chipset drivers, which contains,hopefully what I'm trying to turn on, which is the audio device,which is stopped, therefore won't accept the offered drivers.
That sounds right, your onboard audio is definitely enabled.
What kind of graphics card are you running. I've had problem with the high def bus on my ATI card before, just had to go download an audio driver from ATI.
