audio but no video
16 Apr 2006
Basingstoke
i'm trying to play videos in WMP, and divX player & all that happenes is I get audio, but no video, any ideas? i've installed various codec packs and and reinstallng both sets of software & it still isn't working.
any ideas?
I'd suggest you uninstall all the codec packs you've installed, and get K-lite Codec Pack. Then run the Codec Tweak Tool, and check the option "Detect Broken Codecs".
Then try opening your file in Media Player Classic, which should be included with the pack.
*Waits for someone to smack me with a wet fish, because they think codec packs are crap*
tried VLC, and nothing with the codec packs listed, strange things is they work on laptop which only has classic WMP & divX player with no codec packs
it's 1 of those strange things that happen, couple of days ago everything was working fine, went to watch a vid the next and the problem started
tried that codec pack & still the same problem with Mpg, wmv & Avi's so i'm totally :s
new bit: right, done a system restore and all is now working, but WMP is using around 50% CPU, and is very unstable
has media player recently been asked to update its libary and then you;ve clicked "close" so it does it in the background? I've done that before and with the amount of music/video its been adding its been sat at 40-50% for a long time.
