Audio Crackling and popping - WIndows 7 64 Bit
26 Jun 2013
As above, ever since using the 64 Bit version I get crackling and popping through all Audio devices.....inc usb head phones
Any suggestions please as I'm stumped!
yes try disabling c1e in the bios,and see if noise goes away
also try unplugging the front panel usb headers from the motherboard and see if noise is still heard through your headphones(if usb headphones you would need to try and power them externally,like a usb/3pin plug phone charger ect) ones that htc use
disabled c1e, big improvement, but not completely gone......
headphones are Razor - Megaladon, so cant power externally....
any other suggestions please?
right click speaker icon bottom right of taskbar,playback devices/and high def audio device,right click it and disable
Oh well, not cured, not as bad but still get crackling every now and again with USB head phones and straight from my sound card., Any other things to try please?
check DPC latency. if you have big spikes it'll likely be a driver for something causing the issue. try different drivers for mobo chipset/gfx etc until you find the culprit.
for me, i have a focusrite saffire pro 24, and using the latest firewire driver causes cracking/popping, but switching to the legacy one fixes the issue. don't know if you'll have the same thing with usb tho, but worth a look.
That's useful, thankyou.....will spend some time with drivers!! what a pain. though.
you'll still get crackle if the headphones are usb powered,emi leaks from the usb port into the front panel headphone socket and that's what your hearing
to eliminate it would be to power the headphones from another source or to use non usb powered headphones
could buy a usb extender cable and plug it into the back of pc instead of the front and use the front audio socket
I just received my USB sound card i ordered a few days ago, and it has eliminated any noise i was getting, might be worth looking into, was only £2 and buy one get one free.
the problem is I already have a good quality sound card and the Logitech z5550 system, which was great until I started getting the crackling! Just added another 770 GTX and unloaded loads of odd drivers I noticed that we not needed. Will test again later and report back my findings.
getting really annoying now, uninstalled loads of drivers and changed but still have the odd popping / crackling noise. Starting to think maybe its the motherboard causing the issues. The only thing I haven't done yet is disconnect the front USB 3 ports as I use them all the time......what are your thoughts please?
I have the Razer Megaladon and have exactly the same issue.
Regardless of what I've tried it just seems to be an issue caused by it being a USB input device. The only luck I've had is using normal headphones plugged into the soundcard.
I have never experienced this before and I have had the same sound card / speaker set-up for a few years now....which makes me think its motherboard related, possibly graphics cards as well......cant be arsed to remove them now though to test.
a bit more of an update.
Just received my Plantronics Gamescom 780 headset, connected via USb and this time I have no crackling / popping at all.
