Hi there,
I’m having problems with my audio on my newly built machine. I am experiencing slight crackling/popping jumps when playing audio in a media player player or streaming online. The characteristics are that when I scroll up and down on a webpage I get the crackling. It’s not guaranteed that it happens every time I do this however for instance if I scroll up and down constantly it doesn’t happen continuously and happens but is now and then. The problem also happens when I am not in a browser just performing normal windows tasks. It seems to happen less frequently but it’s defiantly there.
My system I built is using the old HDD and I have installed the latest drivers etc and I think I am all up to date with these. I am running a M-Audio 192 soundcard and I am confident it’s not the cables etc. I have tried various things such as reinstalling the drivers for this card. Removing the HD Audio Genie software that is a live update for the motherboard. Disabling USB 3.0 in the Bios.
I’m open to all suggestions because I’m tearing my hair out!!
My System specs are
MSI GD65 G3
I7 2700 3.5Ghz
16GB Ram Kingston 1600mhz
M-Audio 192
Asus GTX 560 CU2
Fostex PM2 monitors
Running Windows 7 64
Thanks
Haydn
My System specs are
MSI GD65 G3
I7 2700 3.5Ghz
M-Audio 192
Asus GTX 560 CU2
Fostex PM2 monitors
Thanks
Haydn
