Audio cutting out in games
25 Aug 2020
Right so im unsure of how to fix this issue, so ill be playing games like valorant, and ill be fine for like 10 minutes but eventually my audio starts cutting out, so i can barely hear the game, and it doesnt stop at all, sometimes when it happens my discord mic stops working for a little while too, its like some sort of connection problem i believe or somethings wrong, I have good specs which can run the game, consisiting of, i7-3770 2060 super, 16gb ram. Someone help thanks
Is it onboard sound?
Logical thought is to go Device Manager and check sound drivers, perhaps uninstall and reinstall drivers. The restart PC. If the issue persists, it might be of further concern.
If it is a hardware problem, perhaps the motherboard is overheating and causing issues in games.
If you get sound via the HDMI port on the graphics card, then uninstall and reinstall your GPU drivers.
If a software fix fails, then you may consider two options, RMA he motherboard etc as faulty for replacement.
Or an easy fix, buy a soundcard, external or internal one.
I have a Creative Sound blaster Z, works in Windows 10 perfectly.
