25 Sep 2009 at 22:12 #1 Neoni Neoni Soldato Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. Any idea of how i can bounce out of protools, using a 003 rack, routed through a yamaha 01V and out again? Cabling, process etc, my heads a shed! -Neoni
26 Sep 2009 at 04:50 #2 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. Edit: Sussed it just need the cables now: Protools (8 Analogue outs) to Pre's on 01V, then SPDIF on 01V back into SPDIF onto Protools.
26 Sep 2009 at 08:39 #3 R.O.S.S.I R.O.S.S.I Soldato Joined 16 Nov 2002 Posts 11,286 Location The Moon You may aswell have been speaking Aramaic to me then Neoni!
26 Sep 2009 at 20:52 #4 banja banja Soldato Joined 4 Aug 2006 Posts 2,538 Why did you want / need to do it that way? Is it make use of the pres or FX on the mixer?
27 Sep 2009 at 02:54 #5 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. banja said: Why did you want / need to do it that way? Is it make use of the pres or FX on the mixer? Click to expand... So i can mix on the desk rather than inside the box, basically get the sound of the desk too eq's reverbs etc
27 Sep 2009 at 04:50 #6 benneh benneh Soldato Joined 9 Apr 2004 Posts 9,162 Location Nr. brumijum Shocked at how cheap o2r's are now.. (incidentally, I was looking earlier).
27 Sep 2009 at 04:56 #7 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. benneh said: Shocked at how cheap o2r's are now.. (incidentally, I was looking earlier). Click to expand... still not bad bits of kit, nor is the 01V its dated technology now, but very robust, and still sound great! thing is the 02R is not bad money nor the 01V but for full potential you need the adat which is an extra 300+ then for the 02R the meter bridge too!
