Audio managment on creative V player?
19 Oct 2002
Leicester
I know this is a stupid question but one that i have been faffing around with for a couple hours now.
I got a 2gb creative V player and i have started putting some CD's onto it. Just for example i got Hed Kandi, The mix.
Its 3 cd's. I just been using WMP 11 to rip and encode them (WMA) and then sync up with the player.
Now when i go to use the player under albums its list each CD, i dont want this i would like to have a folder called "hed kandi" and then folders in the with all my hed kandi stuff.......which i have around 6 odd.
I have tryed to see if winamp is any better but i cant seem to do it with that either
I know this is going to be one of them thing, so easy if you know how but i just dont ;)
if youve installed the software just open the zen explorer thing and you can make folders and change stuff around, its like a windows folder so you can do whatever setup you like with your music, and you can drag stuff in there, no point using a player to sync, just copy n paste the music to the folder :p
I have done that, just copyed folders over using explorer.
Made a folder in the "music" folder on the zen and within that made one called "hed kandi", then copyed over the relevent cd's and still you look at your albums on the player and it just displayed about 10 HK cd's and not just a folder called hed kandi.
I know im not making myself very clear probley, will post some pics tonight :)
But i still would like to keep each cd septate.
What im trying to go for is :-
My Computer\My Zen\Storage Media\Music\HK
Then :-
My Computer\My Zen\Storage Media\Music\HK\relevant cd's
So im trying to use the zen kinda more like a folder tree if possible instead of going for albums
well i think the closest your gonna get is put a HK folder into your albums, then add all the cd's in folders to that.
open this directory
ZEN V Series Media Explorer\Creative Zen V Plus ( My Zen )\Media Library\Albums
and add a folder called 'hk' then add cd's into that.
then when you go onto the player you can go onto albums, then u have all ** albums, and a hk folder will be there, then u will have all your cd's inside that :P hope thats what u wanted anyway
