- 9 May 2022
- London
I have been having a problem with small audio artifacts (really minor audio glitches) whenever I use wireless headphones on my PC. They come and go but every minute at least I hear a couple of small glitches in the audio. At first, I thought it might be a problem with my wireless Steel Series Artcis headphones so I picked up some wireless Razer Barracuda X headphones but the same problem exists on them.
Then I thought it might be Bluetooth interference, however, neither set of headphones is Bluetooth compatible (both use USB dongles and 2.4ghz frequency). Regardless I turned off Bluetooth in Windows and unsurprisingly it made no difference.
I have tried putting the dongles in different USB ports as well as removing every other USB device from the computer apart from dongle, mouse and keyboard, it did not fix anything. I even tried plugging the dongles into a powered USB hub but again... no joy.
Everything was working fine, then one day this started happening. There are no new wireless devices in the house, no microwaves, and the only other wireless devices in the house are the Virgin Media Superhub 5 downstairs and a couple of mobiles and computers (in different rooms) that connect to the router.
Does anyone have any suggestions on how to go about diagnosing what is causing this and what steps I can take to find a solution?
edit: as soon as I plug the headphones in with a jack cable the audio is fine, so it must be related to the wireless.
