Audio port issues, sound muffled
29 Dec 2012
I dont know how ive done it or what the issues is but im having Audio port issues, the sound is muffled when you fulling insert the jack front ports or back, I have re assigning the mic jack to headset, I tried 3 ports in total headset, reassigned mic and the back port, ive also used 2 diffrent headsets, and its the same for all, the sound is muffled when the jack is fully in but clear partly in. ive re downloaded the audio driver and re installed them, its not worked.
the jacks work all work if i only put it in slightly.
any ideas ?
