I've got my Humax HDR FOX T2 freeview box hooked up to a Samsung UE43M5500 via HDMI , and the optical audio out from the TV to a Teac AV amp. No optical in on the Teac so i use an opt./phono converter. Works fine
My problem is that audio on live viewing through the Humax is fine using the Humax remote, as well as being able to use the amp volume. But with recorded material on the Humax, the volume on the remote no longer works, and only the amp volume can be used to raise or lower the volume
It never used to behave in this way. Its only since i had to replace my TV. The last TV, which actually fell off the wall bracket ( oops ) and wrecked the screen, was another Samsung smart TV, and volume control could be used on both Humax remote and Teac amp, with either recorded material or live TV
I'm a tad perplexed at why simply changing one smart Samsung TV for another has suddenly disabled the Humax remote from changing volume on Humax recordings
