Hi,
The front panel audio cable that came with my Bitfenix Prodigy case seems to be damaged, I can't find a replacement for this.
The BitFenix Alchemy Internal Audio Extension Adaptor (30cm) I have purchased doesn't have the right connector for the front panel.
(linked photo shows the audio cable connection to front panel)
http://bit.ly/1t5CTCn
Is there a cable I can buy - or a relatively simple rewiring of the alchemy cable to the connector from the damaged cable?
Thanks.
Thanks.
