Authy alternative on macOS and iOS?
1 Nov 2007
England
I'm looking to change my 2FA app from Authy to something else. I use Bitwarden as my password manager and know that it does TOTP but wanted to see what the other options were. Would need to support macOS, iOS and iPadOS.
There's loads, 1Password, BW (which you have), Dashlane etc.
1Password. Worth every penny for the fact that it handles everything. I don't think anything else integrates so well or is so easy to use.
If it's only within Apple's ecosystem, why not use Keychain? It supports passkeys, OTP codes, will sync across all your devices, is end-to-end encrypted, and is seamlessly integrated with Face/TouchID and Safari etc.
I think OP wants push notifications ‘did you just try and sign in’ which I don’t think the Apple system currently supports.
Ah I didn't get that. I use Vaultwarden (self-hosted Bitwarden) anyway and it does the job perfectly. Since the OP already uses BW and wanted alternatives, Keychain was the only one not mentioned. I had a look at it again recently due to passkeys (which BW also supports now), and I was surprised how much more functionality Apple (finally) baked in, like OTP and passkeys etc. If they're using BW though I'd stick with that, because it works quite well and is cheap to free.
