I have a Belinea 22" Artistline which seems to have developed a problem with its autoadjust.
It doesn't get the adjustment right, usually its only a little off and I don't really notice until I get a headache as it blurs the text slightly.
The main issue is that the monitor adjusts every time it loses signal so if the pc goes into sleep mode it does it. Main issue being it does it when you load a game, and since the auto adjust wont get it right unless theres a load of text on the screen you can't do much about it.
Is this something I have to live with or will they replace/repair the monitor (its just over a year old)?
