18 Jan 2007 at 19:56 #1 n3x n3x Associate Joined 2 Nov 2005 Posts 956 Location Surrey Does anyone know if there a program or tool that automatically adjusts a programs cpu priority when it is opened? can it be done in windows? T'would be really handy
18 Jan 2007 at 19:59 #2 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,658 Location Sol System WinLauncherXp - lets you set priority and affinity. http://www.majorgeeks.com/WinLauncherXP_d870.html
18 Jan 2007 at 20:17 #3 n3x n3x Associate OP Joined 2 Nov 2005 Posts 956 Location Surrey cheers modo, i cant seem to get it to work unless i launch the app from within that program... am i doing something wrong?
18 Jan 2007 at 20:19 #4 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,658 Location Sol System Yeah you need to run it from within winlauncher, I've not found any app that lets you launch a prog normally.
18 Jan 2007 at 20:30 #5 n3x n3x Associate OP Joined 2 Nov 2005 Posts 956 Location Surrey I found a program called ProcessSwitch that seems to do it, only problem is it only lets you choose from low, normal, high and realtime
