Auto login to vista
dss
dss
6 Oct 2007
Is there a way that you can automatically log into vista (ultimate) when you reboot, so you do not have to enter your password every time? So after your computer boots up, it will log into your account automatically, thanks
windows key & r (do that in windows), then type this and press enter..
control userpasswords2
untick the 'must enter password', then type in your username & password into the fields and press ok
no you can do this in xp and 2000 aswell
minlogon is totally different, that basically logs you in as system, and doesn't understand ntfs permissions, awesome for a standalone pc, crap for a networked one :p
