Hi guys, I'm having this real b*stard of a problem at the moment where, very intermittently, usually under some kind of load, my pc just reboots without warning. By this I mean the screens just all of a sudden go black and then the pc starts up as if someone just pressed the reset button.
I've noticed this happen so far, intermittently, (sometimes within 5 minutes sometimes after an hour or two, some times not at all) with the following operations:
There's been a couple of other games as well I think but otherwise a lot of stuff seems to never trigger it no matter how much I use/play. Also it's never happened whilst idle.
I've run 2 passes of mem test which I know isn't very exhaustive but that alone took about 10 hours on my 16gb ram and came up with nothing. Fans are all turning and temps are consistently good. In an effort to rule out software to some degree I've reinstalled windows and re-downloaded all drivers anew (all more up to date than previously). Since the reinstall, I've played battlefield for a good few hours and it's been fine, however whilst saving a video out in movie maker, it happened again
I've attached a screenshot of the error report in event viewer as well as a capture of my HWMonitor with my voltages etc. I'm not sure what is needed to work out whats wrong but hopefully this will help!
Currently I'm thinking that it could be my voltages as that -12v looks kinda crazy but since my understanding of these things is limited, I want to rule out software before spending money on new hardware...
Any help you guys can provide will be much appreciated.
Cheers!
- Battlefield 3 (game)
- Saving videos in Windows Movie Maker
- Space Marine (game)
- Photoshop CS5
Cheers!
