11 Mar 2007 at 13:18 #1 Warpy Warpy Associate Joined 7 Feb 2007 Posts 372 Is it possible to auto span iso's at 4gb each if the total file size is 6.5GB? Cheers
11 Mar 2007 at 14:22 #2 sajtion sajtion Associate Joined 2 Jul 2005 Posts 818 i asked this once and was told no
12 Mar 2007 at 07:59 #4 bledd bledd Don Joined 21 Oct 2002 Posts 46,884 Location Parts Unknown what do you mean? when creating them? why do you need to span them, ntfs can hold large files
12 Mar 2007 at 12:23 #5 Warpy Warpy Associate OP Joined 7 Feb 2007 Posts 372 I want to backup a Image file thats 6.5GB across two 4.7gb DVD's
12 Mar 2007 at 12:28 #6 TrUz TrUz Associate Joined 18 Oct 2002 Posts 2,154 Location Leicester, UK Dual layer DVD needed here. Or if you only need to store it use WinRAR to split the file and create 2 data DVD's. TrUz
12 Mar 2007 at 13:22 #7 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK TrUz said: Dual layer DVD needed here. Or if you only need to store it use WinRAR to split the file and create 2 data DVD's. TrUz Click to expand... Was also going to suggest RAR'ing the file..
12 Mar 2007 at 13:28 #8 bledd bledd Don Joined 21 Oct 2002 Posts 46,884 Location Parts Unknown you could mount it in virtual clone drive or something and work with it from there
