auto switch apps or virtual desktops
3 Jan 2003
We have a 42" lcd TV at work that is going to show the status of all servers/sites on our network. There is a Windows XP PC displaying the information. I want it to be able to cycle through open windows automatically as each window will be showing different info!
or perhaps do it using virtual desktops if they can be cycled automatically.
cheers
use a macro that presses alt-tab?
or, if the box has a nvidia card, use the virtual desktops that you can enable with nView, and then use a macro to switch between the vDesktops :)
