panthro said:How feasible is it to change an auto gearbox to a manual gearbox, if the automatic car in question has a manual brother? Can it be a straight swap or is it more complex?
moss said:Depends on the car, usually its fairly tricky and probably easier to buy manual version if availiable.
Adz said:Isn't the auto 'box the one to have with the Supra anyway, hence why there are so many of them about? It's more of a cruiser than a sports car so the auto probably suits it quite well.
Disclaimer: One could be talking from one's rectum![]()
pinkaardvark said:Never liked the idea of a twin turbo changing gear mid bend without my direct instruction![]()
but I guess that's why god invented traction control...mattx2 said:I take it your talking about the mkiv supra, if so check out this guide
http://www.mkiv.com/techarticles/auto_to_6spd_swap/index.html
unless you could do all the labour yourself it would be cheaper to buy the manual version theres plenty around some going for as little as 7/8k
also at least try the auto version its a very good box and not like normal auto's its changes are very predictable and smooth
Clarkey said:As good as it is, its never going to be like driving a manual. That said, a lot of drivers like to overestimate their ability, there's a guy on the 300zx forum who has proven many time that an automatic can be lapped quicker than a manual, its all about the driving, not the car.
