AutoGenerateSelectButton with a column header
8 Mar 2005
London, UK
Hopefully an easy one!
So currently I have a gridview which links to another page which works perfectly. However I also wish to export the gridview to CSV which also works perfectly with the exception it treats the appended select field as another column and consequently shifts the column headers to the left misaligning the data to the header and omitting the last columns data.
Is there an obvious way to create a column header for the appended select button? Alternatively cater for this within the vb behind the export button
Code:
   Protected Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Response.Clear()
        Response.Buffer = True
        Response.AddHeader("content-disposition", "attachment;filename=GridViewExport.csv")
        Response.Charset = ""
        Response.ContentType = "application/text"
        GridView1.AllowPaging = False
        GridView1.DataBind()
        Dim sb As New StringBuilder()
        For k As Integer = 0 To GridView1.Columns.Count - 1
            'add separator
            sb.Append(GridView1.Columns(k).HeaderText + ","c)
        Next
        'append new line
        sb.Append(vbCr & vbLf)
        For i As Integer = 0 To GridView1.Rows.Count - 1
                'add separator
                sb.Append(GridView1.Rows(i).Cells(k).Text + ","c).Replace(" ", String.Empty)
            Next
            'append new line
        Next
        Response.Output.Write(sb.ToString())
        Response.Flush()
        Response.End()
    End Sub
Cheers, Paul.
Could you just change this line:
Code:
To skip over the column containing the select button?
Either:
0 To GridView1.Columns.Count - 2 (if the select button is in the last column)
or:
1 To GridView1.Columns.Count - 1 (if the select button is in the first column)
Hmm ok, So that works but it still omits the last columns data (but it does include the column header).
Hmm.
You have that same line in twice, once to get the headers then again to get each column data.
Just edit both the same should do it.
Code:
Code:
        Response.Clear()
        For k As Integer = 1 To GridView1.Columns.Count - 1
            'add separator
        Next
        'append new line
                'add separator
            Next
            'append new line
        Next
        Response.Flush()
        Response.End()
    End Sub
Setting both to 1 shifts the header column to the left and the last data column is still omitted.
Code:
        Response.Clear()
            'add separator
        Next
        'append new line
                'add separator
            Next
            'append new line
        Next
        Response.Flush()
        Response.End()
    End Sub
This sets the header column correctly and shifts the data left so it's aligned, but it omits the last column data (header is there). It's as if I need to tell it to read an additional data column since I've skipped the first.
Worked it out;second for K loop.
Code:
        Response.Clear()
            'add separator
        Next
        'append new line
            For k As Integer = 1 To GridView1.Columns.Count - 0
                'add separator
            Next
            'append new line
        Next
        Response.Flush()
        Response.End()
    End Sub
