AutoGK Encoding Question
Don't think it can plus H264 is quicktime only so would be x264 give staxrip a go as it will convert most files to different formats, i use it all the time to convert to x264, if you need some profiles for converting i will find them plus it comes with ipod profiles already
I've read a little about staxrip but it looks a bit daunting. However, some profiles would be handy to learn and experiment with.
Just place in the profile folder, there for different file size's i use which you can change if you need
X264 CE BaseLine / MP4
Audio Nero AAC HE VBR 50-70 kpb's
Download
