- 10 Apr 2004
Ok basically I need a script/workflow/ANYTHING to help me update 4000 images with watermarked and high res versions using the originals to be re-uploaded to the gallery.
So hers goes:
Gallery images:
/foldera/normal_IMG_0001.jpg
/foldera/normal_IMG_0002.jpg
/foldera/normal_IMG_0003.jpg
/foldera/normal_IMG_0004.jpg
etc
Original is in:
/folderb/IMG_0001.CR2 (RAW image)
/folderb/IMG_0002.CR2 (RAW image)
/folderb/IMG_0003.JPG
/folderb/IMG_0004.JPG
So the script would be given the folder with the gallery images. Then it needs to go find the images original in folder b, then it has to my already running workflow script to watermark/size/save for web them.
Any ideas?
Cheers CR
So hers goes:
Gallery images:
etc
Original is in:
Any ideas?
Cheers CR
How?
